T5 vibration problem
Old May 1, 2002 | 11:01 AM
indy82tx's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
I’ve got a vibration problem on my 82 305 (LU5) with a T5. If I push in the clutch with the T5 in gear while driving at 60-70 mph I get a vibration. I’m pretty sure it’s not the engine or the flywheel because the engine is at idle and the vibration still exists. I’m thinking it’s either the clutch disc or the drive shaft. Could it be that when the clutch is engaged the engine absorbs the vibration? Any suggestions?
Thanks,
Ken
82 Z28, LU5 still alive
Old May 1, 2002 | 08:11 PM
84silverbirdSE's Avatar
Car: '79 T/A and '84 T/A
Engine: 455 buick and 305 chevy
Transmission: TH400 and T-5
i have a similar problem with my 84 S/E T/A LG4 T5. At 60 and above the car vibrates.
on your car,does this only happen between 60-70? what gear(s)? is it only when you disenguage the clutch (pedal pressed to the floor)?
:rockon: :rockon:
Old May 2, 2002 | 07:18 AM
indy82tx's Avatar
Engine: 305 LU5
I've got 3.42 gears. I guess the problem starts aroung 60mph and gets worse as speed increases. I noticed yesterday that the vibration also occurs when the transmission is in neutral and the clutch is released when speed is over 60 mph. It must be the driveshaft or the transmission.
Old May 2, 2002 | 04:12 PM
i dont think it has anything to do with the gears in the rear. my vibration starts at 60 too, and i have 3.73 's.
you should set the rear up on jack stands and run it up to 60mph
to see if the vibration is still there. if it is then you know you can rule out the front causing the vibration. now you know it's something from the tranny back. driveshaft,u-joints,rear axle,tires need balencing,or mayby your really low on tranny or rear end fluid that it just causes the vibs
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
