Replace clip or whole cable??
Old May 2, 2002 | 08:25 PM
RICHRAD's Avatar
The plastic clip which attaches the cable to the throttle is broken. It is still attached to the wire though , but will no longer snap on the stud. I have another good clip I've found but to use it I would have to get that little crimp nut off. I've tried to sqeeze it from the other side but the cable won't slip off it. Can I cut the cable close to the nut , slip it through the clip , then locate one of these crimp nuts and reuse the tv cable ? Or by cutting the 3/16 - 1/4 off Is the cable useless? Thanks
Old May 3, 2002 | 06:13 PM
RICHRAD's Avatar
Sorry, forgot to mention, it's my TV cable which the clip broke on. Can anyone help. Can I cut a little off , slip another clip on there or is there some professional way to reverse the force of that crimp nut?
Old May 3, 2002 | 09:44 PM
ArrioZ28's Avatar
I think they sell (can't think of who at the moment) repair ends for throttle and TV cables that have a small slit in them to allow you to slide it over the cable and retain the stock crimp.
Another trick you could try is to carefully cut a slit the extra plastic clip with a jewlers saw or Dremel tool. Then slip it onto the cable.
Hope this helps.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
