Hooking up tranny cooler, the saga continues...
Old May 3, 2002 | 05:08 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
OK, i had everything i thought i needed to hook up my tranny cooler with braided line. Until my dumb *** realized that AN was not normal flar and that i will now need to get some AN to pipe adapters to interface my cooler and stock hard lines. On top of that, i also have no idea how to get the ends on the braided line.
Thus, i'm ready to call that a lesson learned and just do my cooler in hard line. My question is, is brass tubing OK to use. I can't think of any reason why not but i figure i'll just check. I can get the brass tube i need and flare nuts for cheaper than the new adapter fittings i need, and flaring and bending it is gravy.
thanks for any comments...
Old May 3, 2002 | 10:59 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I don't know of any reason why brass fittings would'nt work-hell guys use them for fuel lines and that's pretty corrosive. I ran into kinda the same problem hooking up my line lock-our cars have those stupid bubble flares and nobody in town had adapters to change it to normal 3/16" brake line and flare fittings. So I got out the tubing cutter and put double flare fitting on everthing (except rear-I'll do that when I put that line lock in) At least now I can get parts (if needed) at any parts store.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
FormulasOnly
Oct 2, 2015 05:52 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
