Why does mine have the governor??!!
Old May 6, 2002 | 01:15 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Alright guys..I have an 88 iroc 305 TPI with the T-5. I used to have 3.08 gears but it blew out so i got 3.45 i think...but anyways, I was wonder how to get the governor off...it seems to kick on at 3000 RPM's....I just got beat by a civic si cause it only does 120..thanks
Old May 6, 2002 | 03:29 PM
82camaro's Avatar
Car: 82 camaro SC
With the 3.08 gears, 3000 rpm is aroudn 120. Since the gear swap your speedo is off. With those gears 3000 rpm is around 106mph. A chip reprogram may fix the speed limiter.
Old May 6, 2002 | 04:29 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There are 2 ways around the governor. If you try using the search feature i bet you could find both of them
Old May 8, 2002 | 09:14 AM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
What kin dof chip would you guys recommend...I have a couple friends that have bought them and they havent worked too well. Thanks for the info
Old May 8, 2002 | 12:05 PM
Ed Maher's Avatar
Car: 04 GTO
https://www.thirdgen.org/techbb2/sho...hreadid=104792
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Dec 8, 2015 12:25 AM
thejimsterz28
Sep 30, 2015 08:52 PM
tattmann
Sep 27, 2015 05:20 PM
