Have axle numbers, but no referance
Old May 12, 2002 | 04:57 PM
ArrioZ28's Avatar
I was doing the rear brakes on my camaro and decided to check the axle code that is stamped on the axle tube. I couldn't find a referance to cross the number to determine what I have for a diff and ratio.
I have a 1984 Z28 5.0 HO 5spd w/rear disks.
Here is the number on the axle tube:
6PM 6232 1
If anyone can cross these numbers, I'd appreciate it.
Thanks.
Old May 12, 2002 | 07:09 PM
ArrioZ28's Avatar
Well, I found a referance for the axle codes at :
http://www.thirdgenresource.com/colo...g.html?sid=284
It turns out that my rear axle has a 10 bolt 3.73 ratio and is not locking. Though I dont know what diameter gear it is.
Its not too bad. I may stick this axle in my 82 Z28 that I just bought and build it up for a sport racer. (I hope to play at the track some) The 82 currently has rear drums.
I got a pretty good deal on this 82. I paid $800 for the whole car. It has a newly rebuilt 350 with new Edelbrock carb, intake and Accel distributor. The car itself needs a bit of work. My original intention was to part the car out. but I later thought it may be ok to fix it up to run down the strip occasionally.
I will find a later model axle assembly with disks for the 84 Z28.
(or maybe just find another axle for the 82, .... decisions decisions..)
6speedIROC
16
Mar 15, 2023 08:33 PM
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Sep 20, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
