How do I take out axle shaft on BW 9 bolt? Please help NOW!!
Old May 13, 2002 | 05:40 PM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
I took the cover off cuz I was ready to fly but the diff looks different than the one I did before.
There are two caps that look like crank journal caps on each side of the diff. I can't see where there is a C clip or something to slide the axle shaft out. I figure that maybe I take off the cap on the side I want to remove and that maybe the clip will be under it or something. I can see that the caps hold bearings and the diff in place.
If anyone knows what I need to do please write back by tonight. I am taking the axle to the machine shop to be repaired tomorrow morning. I don't want to be without my daily driver for long.
Thanks guys.
It's the 2.77 rear with 7.75" ring gear. Code J65
Old May 13, 2002 | 06:01 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You don't have to take the rear cover off on a 9 bolt, because it does not have c clips. Just remove the tire, brakes and rotor. Then remove the 4 bolts that hold on the axle flange. The axle will then slide out (may need a small slide hammer).
Miles
www.9bolt.com
Old May 13, 2002 | 06:05 PM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Thanks. That was quick. You guys are the best. nm
f
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
greenyone
Sep 2, 2015 03:39 PM
