Pushing in on the clutch!
Old May 27, 2002 | 08:52 PM
Zya's Avatar
Zya
My friends like to sit in my camaro and dream they could drive it and play around with the 6 speed! They shift the gears without pushing in on the clutch. Is this bad for the car? Keep in mind the car is not running!
Old May 27, 2002 | 09:44 PM
Momar's Avatar
I dont really know but wouldnt see why it would be. By the way, how old are your friends?
Ben
Old May 28, 2002 | 03:36 PM
Zya's Avatar
Zya
There 16 and 17 but they drive 4 bangers and want to experience v8 power. And like I tell them we all can dream!
Old May 30, 2002 | 10:55 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have been told to press the clutch when doing that... although I am not sure why. I think it allows the input shaft to rotate so you don't put strain on the gears/syncros. That would be my guess.
Old May 30, 2002 | 02:24 PM
HenryC's Avatar
No danger
They are free to shift w/o the clutch with the car parked all day long. If they try to put the transmission in gear, and it won't let thim, it feels like they are hitting a wall, then they will need to push the clutch in the first time, but if it slides in, its fine. Stress is put on the transmission when you shift clutchless b/c the engine and transmission are spinning at different speeds, if the car isn't move they are both spinning at the same speed, 0 RPM. Therefore there is no damage done.
-- Henry
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
