How do I flush tranny cooler/lines?
Old May 27, 2002 | 09:32 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
IM swapping in a new tranny and wondering whats a good way to flush them out. Seems simple enough but what do I use? I did a search and someone mentioned you could buy some type of solvent in a can that you hookup to one line and flush it out that way.
How did you guys flush yours out?
Thanks,
Mike
Old May 27, 2002 | 11:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I havent seen it in parts stores but tranny shops have a can of flush they use. It comes in "fix-o-flat" type can that attaches to the cooler lines. It works good and Im sure any transmission place should be able to hook you up.
Old May 28, 2002 | 11:52 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I disconnected the trans, the cooler lines and the radiator too. Then I flushed the trans + lines with solvent but the radiator only with new ATF fluid 2 - 3 times and moved it horizontally for washed and refilled it and later vertically for flushed it.
Regards,
Denis V.
Old May 28, 2002 | 01:00 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Mike,
I wouldn't screw around with flushing out the radiator part of the trans cooler. Simply don't utilize it.
Use a good aftermarket cooler and that is it. I have talked to Dana at Pro-built about this and it makes sense especially if you are worried about engine cooling like I am.
The factory cooler just isn't as efficient as an aftermarket one and I would bypass it. Also, the lines are getting a bit old...bending new hard lines isn't all that hard.
Good luck.
Old May 31, 2002 | 09:14 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks for the replys guys...The tranny is in and working great, I installed the cooler in line with the radiator for now. When time and money permits, I think I will go with a larger cooler and bypass the radiator.
sheachopper
Jul 31, 2019 11:27 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
IROCZ1989
Sep 4, 2015 11:54 AM
