How to Remove shift lever from 5-speed
Old May 28, 2002 | 08:47 AM
gclay's Avatar
Iam removing a 5 speed transmission from a 1983 Camaro to swap into a 1984 Camaro (That currently has an automatic).
I almost completed the removal of the manual, then I found that the shift lever is blocking removal. I looked in theShop Manual and I appear to have overlooked removing the shift lever.
However , the Shop manual does not state HOW to remove the shift lever.
Should I try and unscrew the top half from the bottom Half (I have already tried, and this doesn't look easy. Should I remove the 4 bolts holding the plate at the base of the shifter and try to remove it this way? what will I find after I remove the bolts?
Thank you for your assistance in helping a beginner with this task.
Old May 28, 2002 | 02:16 PM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
Did you remove your center cosoule yet? If not i would, than you'll see why. Have fun anything else jus ask.
Old May 28, 2002 | 02:49 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i had the same problem. i took the bolts out of the base and pulled the entire thing out.
Old May 28, 2002 | 04:01 PM
gclay's Avatar
Heavy_Chevy29. Thank you for your reply.
You said "pulled the entire thing out". It was as simple as this? Or are there some complications I should pay attention to in "pulling the entire thing out" ?
I am refering to How the shifter is linked inside the transmission.
Old May 28, 2002 | 05:02 PM
bubbareno's Avatar
Transmission: t-5
Jus take your time when you remove your counsole. Dont go breaking anything, After its out look down inside. 4-5 bolts to remove your dust cover an the same for the shifter, shifter lifts stright out .
Old May 28, 2002 | 06:29 PM
Car: 84 camaro Z28
Engine: 434sbc
yeah its as simple as that. you must have the console out. once thats out you can pull the carpet back to access the boot(i think its like 6 bolts). once the boot is out you will see 4 bolts at the base of the shift. unbolt it. the shifter and shifter base will pull right out. there really isnt any linkage to to mess up. its like a ball and socket set up.
please feel free to ask any further question.
dan
Old May 29, 2002 | 08:40 AM
gclay's Avatar
Thanks Dan (Heavy_chevy29). (I already have the boot off)
RedLeader289
Jan 22, 2016 03:05 PM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
