T56?
Old May 31, 2002 | 11:07 AM
Mr82transam's Avatar
T56?
I have a 406 block, can I do a T56 conversion? Will I have any problems with an offset bolt pattern starter or the 2pc rear main seal?
Old Jun 3, 2002 | 06:31 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I would love to get an answer to this ? as well. I heard of a internally balanced for 2 piece cranks, but it's prolly a 153 tooth...
I can't find any company that makes a large diameter externally balanced for 2 piece seal flywheel for a factory t56. Is there any hope besides the richmond 6 or the retrofit t56 which use a conventional clutch?
Old Jun 3, 2002 | 08:52 PM
87RS402's Avatar
Can be done with no problems, centerforce makes the correct flywheel.
Old Jun 5, 2002 | 10:25 AM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
how about getting the crank internally balanced so that you can run a 350 flywheel, and a regular starter. I think the t56 will like that a bit more, but just my .02
Old Jun 5, 2002 | 11:09 AM
Thanks for the input.
how about getting the crank internally balanced so that you can run a 350 flywheel and a regular starter
The only problem with this I already have invested and installed an forged crank and prefer not pull the motor. This car is my daily driver. Also regarding the starter there is no place to bolt a regular bolt pattern starter. The block is only capable of accepting a offset bolt pattern starter.
Old Jun 5, 2002 | 11:12 AM
87RS402, thanks I will check out centerforce for the correct flywheel. Also do you have any suggestion on where to get the centerforce flywheel.
Old Jun 5, 2002 | 05:54 PM
87RS402's Avatar
I honestly have no clue where to get it really. I know from past discussions and seeing it their catalog that they make it and it's expensive but beyond that is a mystery to me.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
