How much power can a 10-bolt handle?
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Re: How much power can a 10-bolt handle?
Rob
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your "76" should be a 8.5" 10 bolt.
In stock trim, the 7.5" 10 bolt can be broken with a stock engine. It depends on how much shock load is put into it.
I built one up last year. 4.10 gears, LPW solid rear cover with bearing supports, welded axle tubes, aftermarket 28 spline axles, solid crush sleeve. I ran mid to low 11's with it with no problems.
I went to a 9" over the winter because I went to a very high stall converter and a transbrake and didn't feel the tiny 7.5" gear set could take the abuse of that.
Engine: 400HP 350
I hear you, but my car is not stock, almost a sleeper if you want to say, it looks slow but it's fast. I understand what your saying, any rear end can be broken with enough HP.
Thanks for the info. This past weekend I blew out my 10-bolt rear end. It held up for about a year of abuse, I am running high 11s. This car is also my daily driver, so I think I will get a 12-bolt rear.
Were are some good places to get a 12-bolt besides thunderracing.com.
http://www.spohn.net/index.cfm?fusea...t&productid=52
Also, I was curious what is the ring gear size in a 12 bolt?
Ben
Ben
sailtexas186548
Aug 24, 2015 10:11 PM
