How much power can a 9-bolt handle?
Old Jun 6, 2002 | 09:32 PM
Mr82transam's Avatar
How much power can a 9-bolt handle in stock form? How much power can a modified and rebuilt 9-bolt handle?
Old Jun 6, 2002 | 11:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My stock one with 3.27 gears was pushing high 11's and 1.7x 60 foot times with no problems.
Old Jun 7, 2002 | 12:07 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I have been running mine for almost 4 years behind my big block with no problems. There is an article posted at www.9bolt.com (from Hot Rod magazine) that compares a 9 bolt to a Dana 44. It's a great choice for something between a wimpy 10 bolt and the very expensive (~3000+ with brakes, drive shaft, ujoints, etc....) 9 inch or 12 bolt.
Miles
Diff Solutions
Old Jun 7, 2002 | 07:15 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Miles
Diff Solutions
$3000 ?? I have about $1250 in my 9"!!
Old Jun 7, 2002 | 10:25 AM
Thanks for the info. Miles, I will check out www.9bolt.com.
Old Jun 7, 2002 | 10:30 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Complete 9 inch (less brakes) from Moser ~2200
Brakes ~250
Drive shaft w/ 1350 yokes ~350
Shipping ~200
As with anything, the more creative, the more skills, the more friends, the more tools, etc.... that you have the cost can be reduced.
Miles
Old Jun 7, 2002 | 11:29 AM
Ricktpi's Avatar
$858.00 Axles & F body housing w/ torque arm bracket
$150.00 Used center section
$160.00 3.70 Ring & pinion
$ 25.00 9.5" used 88 Caprice brakes
$18.00 NAPA conversion ujoint
$25.00 Misc fitting & brake lines
$45.00 shipping
Total $1256.00
I'm sure someone else could be more creative than me. If you can find a used center section with the gears you want, subtract $160.
Old Jun 7, 2002 | 02:25 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Miles, I have a 9 bolt too and I think it is ok into the 12's...especially if the car is street driven as well...
However, I read the Hot Rod article on your site and here is the only text I found referring to the rearend...
"Serious big-block power could also wreak havoc with the rearend. An automatic will cushion the rearend somewhat, but you may have to consider installing a Dana 44 or a 12-bolt with an aftermarket mount kit such as those available from Summers Brothers."
This doesn't exactly sound like a comparison of rear ends to me...
Let me know if I looked at the wrong article...
Thanks,
Old Jun 7, 2002 | 05:18 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The article is posted in the 9 bolt section. Here is a link to it.
http://www.koolmeister.com/hot_rod_article_sm.jpg
Miles
Old Jun 10, 2002 | 02:42 PM
Engine: LS3
Transmission: 6L80E
My bad Miles...thanks for the help.
Is there any other factory or aftermarket documentation on this rear end? Just curious that the review you have appears to be the only info...
Thanks,
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Linson
Nov 12, 2015 08:09 PM
masonta
Sep 1, 2015 06:40 PM
sailtexas186548
Aug 24, 2015 10:11 PM
sreZ28
Aug 14, 2015 07:48 PM
