10 Bolt Axle Questions
Old Jun 9, 2002 | 10:38 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i might pick up a 84' 10 bolt disk rear. i an going to do a mild build-up of the rear. theses rears have 26 spline axles right? so i would need to get a set of 28 spline axles. Are 10 bolt axles the same from either disk or drum? if the axles are the same i will pick up the rear. 89'-up 28 spline axles are plentiful on drum equpped vehicles. i know on 9 bolts the axle flange for a drum is larger.
Old Jun 9, 2002 | 12:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 84 will have 26 spline.
I've never checked the difference between a factory drum and disk axle but the aftermarket axles I used worked with both.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
