Trany???
Old Jun 20, 2002 | 05:58 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
Trany???
I am haveing a new trany put into my car, and i was wondering if any body out there knows about some kind of transmisson oil control *** ( sorry i don't know the real name to that pice) that is by your carb and allows you to adjust the amount off transmission oil that goes through your trany. will if any body out there knows what i am talking about i have some Q's that i would like to ask you:
1. First of all what is the name of that thing?
2. How much hp do you get by pulling the *** all the way out if any?
3. What good thing's come from haveing that in your car?
4. Is there a way that I can control it from the inside of my car and if so how?
5. If i where to drive aroud with it at max flow will it harm my trany in some kind of a way?
Will i think that those are all the Q's for right now and if anybody can answer them it would grate thank's.
Old Jun 21, 2002 | 08:28 AM
Bob86ZZ4's Avatar
I have no idea what you are asking about. I wonder if you are thinking about the TV cable. This is a cable that attaches to the carb (or throtle body) and the transmission. I don't know a lot about it other than it tells the tranny how hard you are gassing it so the tranny adjusts the fluid pressure to make the shifts work best for that amount of throttle. Anybody else here? Am I close on that one?
Old Jun 21, 2002 | 12:37 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
ya tv cable that is what it was called thanks man.
you see the guy that was telling me this **** was speeking spanish and i could not uderstand have the **** he was saying i don't speek it that well.
Old Jun 21, 2002 | 01:09 PM
Bob86ZZ4's Avatar
Okay, the tv cable does need to be adjusted properly to make the tranny work right. It cannot make you get any more power tho.
Old Jun 22, 2002 | 08:36 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
can make you have a bit better acceleratin if it makes your tranny upshift when needed when stomping the gas, if it doesnt do so thne its probably not adjusted correctly, and car can be boggy on acceleration in most cases.
to adjust correctly, take and press down on the D handle lock button thats depressed into the part of the cable housing deal(just behind the intake manifold bracket it is locked into) and push the cable **** thingy that you see just in front of the bracket all the way towards rear of ca then let go of the lock button and then manuallly open the thorttle of the caburetor all the way open and the cable should 'click' when it getsa pulledc oout of the housing a lil, thats it its set, or at least should be,
the goal is to have the cable come out of the housing enough to not restrict the throttle blades in carb from nopt being open all the way yet have no slack in cable when they are open all the way, i remember doping the adjustment to my 700r4 because i was losing my 2-3 shift bad and wow it fixed that plus more, the car is like a brand new car now, and thats with a crappy '84 700r4 tranny even,
good luck
breathment
Dec 14, 2001 08:13 PM
BitchinRS
Oct 2, 2001 12:18 PM
z28crazy
May 17, 2001 03:18 PM
brockrodgers
Jan 11, 2001 06:26 PM
KnightWhoSaysNI83
Dec 25, 2000 07:45 AM
