3:23 gears
Old Jun 20, 2002 | 11:55 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
3:23 gears
I am getting a really good deal on brand new 3:23 gears and I want to know what kinds of gains I can expect out of them? What needs to be done to put them into my rear end?
Old Jun 21, 2002 | 10:22 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
DynoDon just installed Richmond 3.42's in my RS a few weeks ago, noticed a huge difference from the stock 2.73's, much quicker off the line. The Auburn posi & the new gears are one of the best mods that I've done so far. You will need a 3 series carrier because you currently have a 2 series carrier with your stock 2.73's.
Old Jun 21, 2002 | 11:38 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
2-3 tenths faster 1/4 mile.
Old Jun 21, 2002 | 08:46 PM
trans87's Avatar
So it will be a noticable difference in acceleration? How much would a 3 series carrier cost?
Old Jun 21, 2002 | 09:42 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
No he won't, he'll just need to get 3.23 gears meant for the 2 series carrier.
Old Jun 21, 2002 | 09:48 PM
trans87's Avatar
These 3:23s are meant for a 10 bolt which I have so do you think I will need a new carrier?
Old Jun 22, 2002 | 12:36 AM
Dyno Don's Avatar
Axle/Gears: 12 Bolt 3.73
Yep...you will need a 3 series carrier. W/ 26 splines
I can get you one BUT they run about $275
Don>>>
Old Jun 22, 2002 | 01:12 AM
igotslicksNchix's Avatar
hey guys if i go to mechanic and say " i want 3.73's" would he take care of it? and how much would it set me back?
Old Jun 22, 2002 | 01:23 AM
AFrikinGoodTime's Avatar
Good 3.73 gears + install kit will cost you around $350-$400. I would guess labor to be around $200? You never know with shop prices these days.
Old Jun 22, 2002 | 01:56 AM
Engine: 305-4v
Don>>>
Why can't he do what I said and get the 3.23s that fit the 2 series carrier?
Old Jun 22, 2002 | 01:30 PM
trans87's Avatar
Well I don't know which carrier these 3:23 go to. I am getting them though because they are cheap. With the 3 series carrier can I upgrade to 3:73 later without having to change it again?
Old Jun 23, 2002 | 06:02 PM
trans87's Avatar
I still want to know about the carriers. Need to know if the 3 series carrier will work if I eventually change the 3:23 for 3:42 or 3:73?
Old Jun 23, 2002 | 08:37 PM
Engine: 305-4v
They make them for both series 2 or 3. It is only if you want to use the stock GM posi that you must match the 3 series gears to the 3 series carrier. You will have to ask the guy you are buying the gears from whether they are meant for the 2 or 3 series carrier. Even if they are meant for the 2 series carrier, which is what you seem to have, PowerTrax makes a posi that will fit right in, should you eventually want one.
Old Jun 23, 2002 | 09:13 PM
trans87's Avatar
Thanks Sitting Bull and others who responded to this. You have given me new knowledge to go upon
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
