Confirming busted T5
Old Jun 22, 2002 | 09:05 AM
irocbsa's Avatar
Just looking for a little confirmation that my T5 has taken a huge dump. Nothing works but 4th gear. Not even reverse. Was originally hoping it was something like a shift fork but since I don't have reverse.......anyway....
Old Jun 23, 2002 | 03:44 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
soo sorry for you
yep, you blew it. my friend has an '89 Formula with the TPI 305/T5 and i have an '87 Formula with the same combe and his did the same thing. if you are the adventurous type when you get the tranny out, disassemble it, tell me whatcha see, ok? again, sorry about your misfortune and good luck gettin your Camaro back on the road!
Old Jun 23, 2002 | 09:19 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: Confirming busted T5
wow thats a huge dump
seems like everything failed
the reason 4th works is because thats direct drive
sorry to hear that man
it should be pretty easy to rebuild though
i havent done a T5 yet, but i have done other manual trannies at school..............took me about 3 hours with all the right tools at my disposal
good luck
Old Jun 23, 2002 | 10:06 AM
mechanicalmehem's Avatar
the gear on your counter shaft has exploded, and fourth is direct drive therefore you still have it.
Old Jun 25, 2002 | 02:05 PM
irocbsa's Avatar
Just an update, you were all right. The first gear on the countershaft was spun completely smooth. It even hogged out the case about a 1/4" all around. Nasty stuff. Got a new one from a good friend for a good price.
Old Jun 25, 2002 | 03:25 PM
im glad to hear, i can't stand to see a good f-body down!!!!
Old Jun 28, 2002 | 03:23 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Im guessing I got the same problem, I just ordered the master rebuild kit and video but if mine blew that gear its lookin like the rebuild kit wont help....
its been down since I bought it, the tranny went 40 miles on the way home..
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
tyeo098
Nov 30, 2015 06:27 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
buckeyecelt
Sep 24, 2015 05:50 AM
89 formula TPI
Sep 7, 2015 11:06 AM
