Can't smoke 'em! Help!
Old Jun 24, 2002 | 06:32 PM
91BigRedZ28's Avatar
Okay,
I know it's not all that good for the car, but, for the ladies, I do brakestands every now and again. I have Mickey Thompson Sportsman I's in the back. The tread width on these bad boys is twelve inches. Man it looks mean. But I only have a 305 under my foot. Needless to say, I can still spin 'em, but when I'm doing the brakestand, the engine seems to govern itself at 2100 (ish) rpms
If I keep on it for a minute or so, it will jump up and really burn the tires...Why do I have to wait? Why is it holding back? Can I fix it somehow? I'll be at the Summer Nationals in Worcester MA on Fourth of July Weekend, and I planned on throwing some crappy tires on the back and putting on a little smoke-show at the burnouts. So any help would be appreciated.
Old Jun 25, 2002 | 12:05 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Water always works
Old Jun 25, 2002 | 01:12 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
1. Tune up your engine.
2. Or swap in something with more power.
3. Cheat and use water
4. Use one of the above to help...
BTW, what kind of "ladies" really like to see burnouts with a 305?
Just make sure it isn't a relative
Old Jun 25, 2002 | 04:22 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
A trick that's used in VW burnout shows is to have an electric washer fluid reservior installed and have the outlet plumbed to point at the rear tires. Add 1/4 bleach and 3/4 water and you're all set. There's a transition between not spinning and a really good spin where the wheels hop so much in the VW, that it pulls itself out of gear, hence the water injection helper.
Old Jun 25, 2002 | 06:19 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
bleach is awesome for this, but be warned, brakestanding or powerbraking as i call it is supposed to be BAD for the transmission, the rear brakes and even the engine, just making sure you know
Old Jun 25, 2002 | 06:23 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I wonder if wisk detergent would work well Wisk is impossible to wash off your hands cause it is so thick and slippery. Imagine a burnout full of bubbles
Old Jun 25, 2002 | 10:01 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Old Jun 25, 2002 | 10:51 PM
Slade1's Avatar
All I can say is
WHY?
I have gone thru a tranny rebuild and a busted gear set for my differential... if you only knew the pita it is to fix those things, you wouldn't do it....
I dunno bout most of you, but the ladies I know get a kick outta things that just pulls hard and doesn't let up...
Old Jun 25, 2002 | 11:19 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Most girls get a kick out of a clean ride. Just try giving your car a nice car wash and wax job to make it smooth for the ladies.
Old Jun 26, 2002 | 10:17 AM
MdFormula350's Avatar
The thing with brakestands is that when u aply the brakes, all four sides are holding the car, so when you give it gas it takes the power of the engine to break lose the rear brakes, and then after doing you still have to break lose the tires from the ground. So if you have really good tires with good traction then it would be even harder t get the tires to move.
So my advise is to keep what u have and install line locks, i think jegs sells them, what they do is lock the front brakes but not the rear brakes making it easy for you to burnout, and not wearing down ur rear brakes, and take alittle less stress off the tranny.
Old Jun 30, 2002 | 05:01 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Beings how we are tearing s**t up anyway, just crimp the rear brake lines. Wish I had your problems....... You have to wait for the rear brakes to get hot enough that they dont hold....do you have any Idea what kind of stress this is putting on your car? I hope your ladies are impressed whaen you get off the bus...
Old Jun 30, 2002 | 11:06 AM
I do agree that it puts stress on these car, but just the fact that some are like 10+ years old sports car and still preform great after being abused for many years means that they can handle most of it.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
