VSS for the T56 question.
Old Jun 30, 2002 | 09:17 AM
JAY87GTA's Avatar
I did a search, never found a similar problem, so hear goes. I got the Dakota Digital box, wired everything up. Speedo don't work. Double check power and ground, both good. Checked all the splices and crimp connections, all good. Check input signal, nothing. Unhook both leads for the VSS input, drive around, no signal. Ground one lead and drive around, still no signal.
Now, I'm assuming that the VSS on the T56 is a signal pulse generator, therefore producing it's own voltage, and I should be able to read an output voltage with my multimeter. Am I wrong? Or am I correct and have a faulty VSS on the tranny? Any help is appreciated! Later
Old Jun 30, 2002 | 10:48 AM
jimbuck0's Avatar
I had this same problem. I ended up using different switch settings as the input and different output terminals. If i get a chance, I will pull the console and see what I ended up using.
Jim Buckingham
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
