700r4 questions
700r4 questions
my transmission wont shift into overdrive at all....every other gear goes through fine...What could be the problem? tv cables?
can i drive the car in drive on the highway or will that put stress on the engine?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Check your shift cable adjustment, the trans may not really be in the OD position. Do a search for TV cable adjustment by Transfixleo to properly adjust TV cable.
Iroc8t8
May 4, 2026 08:09 PM
