Info for first time auto to 5spd swaps
Old Jul 5, 2002 | 03:28 PM
camaro6spd's Avatar
OMG.....3 hours upside down with my head under the dash.....my neck is killing me.....this swap is not hard just very time consuming and you need to keep your cool....lol...i had to tell that to my self lots of times today...in order to get the clutch/brake assebly out you need to remove two "reinforcing" bars to gain access to 2 of the 4 nuts that hold the pedals to the firewall....no big deal just get your self WAY under that dash and have someone ready to hang you tools....you need to also drop the steering column some...no biggy...two 13mm nuts....then use a BFE (Big Freakin extention) and put a 15mm deep on the end of that and it is easy to gain access to those two of the 4 nuts i was talkn about....this may not make much sense now but just get under there and you will see what i mean. Then to take out the auto pedals it took like 1/2 hour b/c i know what to do.....now i am going on to the installation of the clutch pedal in the auto car.....i will be back.
Old Jul 5, 2002 | 10:01 PM
camaro6spd's Avatar
took 12 hours just to swap the pedals...what a bitch that was
Old Jul 6, 2002 | 03:00 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
damn sounds real hard..i want a 6 when i swap to tpi but if the headache will be to much for a novice with some help from more experienced guys i wont do it...i will just build up the 700r even though i really dont like auto anymore...
Shawn
Old Jul 7, 2002 | 09:18 AM
camaro6spd's Avatar
I wouldn't consider myself a novice but i don't think i am a master yet either.....i have done 2 engine swaps...rear swaps....and all the preventive maintanice to my car...along with lots of small engines and dirtbikes....but it is not hard if you just read over the teah artical but it is a pain in the *** b/c of how tight is is under there you need to just keep telling you self to just do it and not freak out b/c the more you get done now the less you will do later. it sure did make is easier having the stick car right next to the auto car tho...lol....and a person out there to hand you tools as you need them.
Old Jul 7, 2002 | 10:26 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
so far i pulled my auto out
i'm still waiting for my clutch
how did you elevate the T5 high enough to bolt it up?
with a jack?
Old Jul 7, 2002 | 10:38 AM
87RS402's Avatar
with a jack?
Just bench press it up. I've taken a T-5 out and put it back in 3 times now, benching it back up is the easiest way.
Old Jul 7, 2002 | 11:04 AM
kevinc's Avatar
Car: 1982 Z28
If you ever upgrade to a T56 the weight and height is a bit much for 1 person. I broke down and bought a scissor jack specifically for transmissions from Harbor Freight for $50 or so...and it was worth it.
Old Jul 7, 2002 | 11:09 AM
87RS402's Avatar
heh, if you ever upgrade to a T-56 do what I do, get a big friend to come over and bench it.
If all else fails you can get jack adapters to convert your floorjack to a tranny jack.
Old Jul 7, 2002 | 11:53 AM
when i upgrade to the T56....i'm bringing the car to work where i can use the lift
Old Jul 7, 2002 | 05:25 PM
camaro6spd's Avatar
yep....bench it...lol...altho a trans guy told me not to let it hang by its input shaft so...i don't i bench it up there and have someone bring over a jack.
Old Jul 7, 2002 | 06:36 PM
hmmmm
when i put my clutch in on my RS at work, another mechanic helped me lift it up and we let it hang..........
hehe this should be fun, benching it up there............
Old Jul 8, 2002 | 03:51 PM
86Chicken's Avatar
Putting those pedals in is a real !@#$ing nightmare. It took me a bit more than 12 hours to do it the first time. Although, when the slave cylider seal blew I had to do it again and it only took 3 hours.
Practice makes perfect
Dale
Old Jul 8, 2002 | 11:55 PM
Darth_TransAm's Avatar
12 hours!!
What do you mean, a total of 12 hours or 12 hours straight.
I was just about to start the same thing. I don't think that I can do anything for 12 hours straight, except maybe sleep.
I even have the donar car right next to my car. Any other tips?
Old Jul 9, 2002 | 12:34 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
does anybody happen to know if i can use the starter that is on my car with the 700r4 right now, when i swap to my t-5, or will i have to get a different one?, i have heard differing opinions,
and incase you are wondering the current starter is a stock replacement, about 3 months old so i really don't wanna buy a new one again
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
