200 to TH350
Old Jul 12, 2002 | 11:13 PM
shaggyj5's Avatar
200 to TH350
i have an 82 T/A and it has a 200 behind the 305-how strong are these trannys and if i wanted to swap to a th350 is it a bolt in process or will i need a different tranny crossmember and different length driveshaft?
Old Jul 12, 2002 | 11:57 PM
ronterry's Avatar
Car: '94 Corvette
All you'll need is the B&M change over kit for $70 bucks or so.
You'll get to keep the stock drive shaft & crossmember. It's only an issue if you had a 700R4.
TH-350 can handle LOTS more torque then a 200C.
A stock 350 can handle more torque than a 700, & at a 4th of the price. Your going to hear crap from the 700 crowd about no over drive yada yada. **** I had a 91 Grand Am with no OD. **** my '82 & your '82 had no OD
I would say a medium build TH-350 can handle anywhere from 400-500FPT.
A 200C maybe 275FPT, and there's no beefed up after market parts.
Good Luck,
Ron
Old Jul 13, 2002 | 12:05 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I did the same swap when my 200 died. If you have the cash it's a good idea. Th-200c's will die in a tricycle. It's not difficult to swap them. Crossmember works, and so does the driveshaft. You'll need a swap kit made just for this available from jegs or summit to allow you to mount the torque arm onto the th-350. I had a tranny shop build me a th-350 and they did the swap along with a swap kit I got made by B&M. They didn't complain about it. I did see something that looks like fitting adapters for the fluid cooling lines. Don't know for sure if there is a problem there or not. In hindsight I wish I had put in a overdrive. I thought it would be too difficult but it's not too bad, but harder than going to a th-350. Something else to consider anyways.
HTH,
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Night rider327
Oct 9, 2015 09:25 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
ironbmt
Sep 27, 2015 06:00 AM
89newfun
Sep 16, 2015 09:28 AM
