clutch slave/master cylinder
Old Jul 18, 2002 | 06:39 PM
jstarsart's Avatar
I need the hydraulic hose from the master to slave clutch cylinder. I know that it is discontinued for my car (90 RS). I read in another post that like 93-95 setup should work and I can get that whole setup but I want to make sure that they have the same throw. Now this setup will cost more than I'd like to pay but to me shifting is important so I'd like to be able to do it for a while....and good parts are necessary for that IMHO. Any idea where I might be able to get a decent price for everything (slave, master, hyd line, and res.). GM is the only place I currently know that has it available.
Old Jul 18, 2002 | 08:09 PM
Hulk0202's Avatar
Well I believe the setup for the T56 will not fit. Im not sure if there is another version or not.
Old Jul 18, 2002 | 10:09 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
my local autozone claims they have the hose i just have to bring the one i have to match it up...... i have yet to do so
Old Jul 19, 2002 | 03:21 PM
jstarsart's Avatar
hmm...my autozone says they don't have it....i don't have the hose for them to compare it to anyhow
Old Jul 19, 2002 | 03:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Been there, done that.
Auto Zone doesn't have it. They'll try to give you a piece of rubber hose or something like that.
THe only way I know to get it, is to go to the dealer and buy the assembly of both cylinders, the reservoir, and the lines to connect them. I know it's not what you want to hear, but that's better than getting lied to and still not having the part you need.
Old Jul 20, 2002 | 08:42 AM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
Go to a pull apart junkyard and get one from a Manual car. That's what I did. Works beautifully.
Old Jul 20, 2002 | 12:02 PM
jstarsart's Avatar
well i have tried every single junkyard and automotive store around here. no junkyards sell them. all the pick and pulls are stripped clean of them. the only place i can get it, like you said RB83L69, is from gm. But i had them check the price on the one for the 93-95 models. That one is cheaper and i believe i read in another post that in those years they used a steel braided hose intead of rubber or plastic. heres the post https://www.thirdgen.org/techbb2/sho...hydraulic+line anybody else tried or know. I'd like to not spend $150 for something that won't work.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
