83 t-5
Old Jul 18, 2002 | 08:09 PM
black83z's Avatar
83 t-5
Was the 83 5-speed a hydraulic clutch or a manual? What are the advantages/disadvantages to this? Is it more difficult to find performance clutches, etc. for this transmission. Thank you.
Matt
Old Jul 18, 2002 | 11:34 PM
ckayser's Avatar
'83 is a manual set-up with the old style z-bar. Just Check out Summit or Jegs for a clutch, they have it all.....D2M4E.
Old Jul 19, 2002 | 07:56 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Clutches are identical. They do not care what is pushing on them.
I put a hydraulic system in my 83, it is much better than the mechanical one. I re-used the clutch that was there (it was nearly new at the time).
Old Jul 19, 2002 | 08:23 PM
black83z's Avatar
how do you make a car that originally came with a z-bar manual clutch transmision into a hydraulic one? What parts are needed, is it hard? How do i check if the transmision allready has it done? Thank you
Matt
Old Jul 20, 2002 | 08:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need the bell housing, because the slave cylinder bolts to it; the hydraulics; and the entire pedal assembly. You can easily get all these out of a junk car, just look for a v8 RS or some such in the boneyard.
You do not have to change anything about the clutch; the flywheel; or the trans itself.
Old Jul 20, 2002 | 03:22 PM
black83z's Avatar
Would the tech article on this swap still pertain to me then? Is swapping in a manual clutch easier than a hydraulic. Thanks
Matt
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
