Identify Me!
Old Jul 25, 2002 | 02:36 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Identify Me!
I am a super T-10. What are my gear ratios? What did I come out of?
Old Jul 25, 2002 | 02:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How many grooves are cut around your clutch splines on the clutch gear? What is your output shaft size? Do you have a torque arm mount? Does it really matter what you came out of, i.e. are you going to go find it and get back in?
Old Jul 25, 2002 | 03:17 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
26 spline, 3 vertical lines input
I have a turbo 400 output shaft
I do not belive I have a torque arm mount (I came from a junk yard, so I might have had a bracket, but it was lost.)
I am just curious where I came from.
Old Jul 25, 2002 | 03:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You are a very wide ratio, 2.95 1st gear I believe. I'm not sure what you came out of but it isn't a Z28 or Trans Am or Corvette, because all of those would have had a 2-groove 2.65 1st gear. You probably came from a truck.
Old Jul 26, 2002 | 11:18 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I am also a lost part looking for my identity. All I know about myself is I am round, flat and have some sort of friction material on me. I feel a connection between us, although I believe there may be a third member involved. There is just something intriguing about someone with a 2.95 first gear.
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
