put my 4th gen rear in today
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
it seems challenging to replace a rear in your driveway
actually, it was VERY easy to do
i jacked the rear of the car up and put jackstands under it
took off the wheels, set up the jack under the left side control arm
took off the sway bar
removed the shocks from the rear
removed the lower control arm
slowly lowered the jack
spring came out with little to no force
repeated this for the other side
when i got it out from underneath, i took off the torque arm and put it on the new rear
then i put the new rear underneath
i jacked it up on one side and put the lower control arm underneath it didnt bolt it up yet though
then i bolted the shock on and put the spring in
jacked it up and then tightened the LCA
the only thing i didnt do was hook up a parking brake cable
i need to know which one to get and how to hook it up
brakes went on without a problem
oh yeah, the rear is a 3.23/disc/posi from a 94 Z28
so if anyone needs help with their 4th gen rear swap, you can ask me
nope
except for the parking brake cable its a 100% no modification bolt in
the wheels stick out a little more on either side, but it doesnt look bad
Car: 1989 C4
Axle/Gears: 307
Originally posted by 1991tealRSt-topGuy
nope
nope
Actually if you own an early model thirdgen like my 82 the brake line connectors are a slightly different size.
But its no a big deal to fix that problem. Trending Topics
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Go to the dealer and get a set of e-brake cables for a 91 or 92 f-body with rear disc brakes and you should be all set. Check your adjuster though...does it look like this?
Oh yeah, if you're a cheap ***, I've got a set of used e-brake cables lying around if you want them. I won't need them for a while.
Ed, sportin' 1LEs now
Car: 1983 Z28
Engine: 6.6L 406
When I ordered my E-brake cables I got teh 92 Camaro 1st design cables. tehy have a 1st and 2nd design so make sure you get the right ones.
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Why won't the original cables work. The replacements alomst look too long judging from the picture in this thread.
where is the ebrake adjuster, exactly? Im looking into doing this swap when i swap out the auto for a 5-spd. How does one go about fitting a 4th gn rear into an 83z? What mods are required and can i do it myself? Do i need a lot of expensive tools i dont have? Thanks
Matt
Matt
Car: 4
Engine: 6
Transmission: 5
Interesting... I put a 91 or 92 rear into my 83, the cables that came with the rear just hooked right up to my adjuster, it hardly even needed a different adjustment from where the drums had been set. I think the brakes are the same on the late 3rd gen and 4th gen rears but I don't know that for sure. No mods were required except that I got the last few inches of steel line (metric) off the 91-92 car, and cut the same amoutn off the SAE line in my 83, and spliced the metric end onto the SAE line with a flare union.
wm_sorg:
Those lines are Earl's braided lines and seem to be a bit longer than the stockers. Also, I haven't installed the brake line keeper on the strut and that's why it's floppin' around out there.
black 83Z:
Look at my picture of the adjuster. It's located in the driveshaft tunnel above the driveshaft almost directly under the e-brake handle. This is an '88, I think the '91-'92s are different somehow.The 4th gen rear will bolt right in but you may have some brake line issues and you will definitely have to change out your master cylinder and prop valves. I would just because they're 20 years old. You should only need basic hand tools. DO a search on "rearend swap".
RB83L69:
Did you install a drum 4th gen rear? I wouldn't think disc/drum cables would be the same. Good job on the splicing!
black 83Z:
RB83L69:
Car: 1983 Z28
Engine: 6.6L 406
You don't have to change you master cyluinder and prop valves. For disc brake cars the rear-end is almost a direct swap all you need is an adaptor for the brake line, The E-brake cables all you need is 92 CAmaro 1st design cables annd you will be all set.
The only way you would need a new master cylinder is if your was already bad.
The only way you would need a new prop valve is if your car was originally drum.
Car: 4
Engine: 6
Transmission: 5
No, I put a 91-92 disk brake rear in my formerly drum car.
It was not even necessary to swap the MC or prop valve, they seem to work perfectly. Balance is excellent front to rear.
Parking brake cables are the same on the car, the part on the rear is of course different. I simply hooked the rear's cables (they came with the rear) to the part that stays with the car, and they hooked right up as if they were meant to go there. Absolutely interchangeable in every detail as far as I could tell.
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i am also in the middle of installing a 4th gen rear...and im home free except fot the e brake cables...i installed a jegster torque arm and i think that completely covers my e brake junction...im screwed!! lol
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
will the extra width of the rear end improve handling? i figured it might since overall 3-4 inches wider or something. have you tested it out yet?
its about 1.5 inches wider on both sides...you can feel the extra width...it feels better....the gears are great and DAMN the disc brakes rock!!! it woulda cost me more to get the gears and put them in my drum rear than this did...i couldnt be happier..
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
4 gen pic
i have a 83 and i'd like to see a picture with the rear in, how far does it stick out on the side. i live in the country and im concerned about throwing rocks at my car with the wider tires/axle. a picture would do me wonders
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
