Removing B&M Shift Improver Kit
Old Jul 30, 2002 | 08:53 PM
BigTiggBoy's Avatar
Car: 1986 Trans Am, 1997 Trans Am WS6
Engine: 5.0 Liter TPI, LT1
Transmission: 700R4, T-56
Axle/Gears: 3.27 9-bolt, 3.42 10 bolt
My transmission is out of the car and I have installed the B&M shift improver kit. After reading the post in this forum, I now want to remove it before I put the trans. back in the TA. Could someone tell me what would happen if I put it back stock and left the enlarged feed holes in the seperator plate? If this is a bad idea(and I have a feeling it is), could someone tell me where I could find a new seperator plate?
Thanks.
Old Jul 31, 2002 | 01:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think you can get one through GM. I asked this a while ago somewhere else, I was told to weld the hole shut and re-drill it. I'm in the same boat, I put the B&M kit in myself, and wouldn't mind taking it out. (sigh) Oh well, I've got to rebuild this trans anyway, it's on it's way out. Except, I won't rebuild this trans- I'll rebuild a junkyard trans, and hopefully it won't have the B&M kit in it.
Old Aug 8, 2002 | 08:31 PM
BigTiggBoy's Avatar
Thanks Tom. I got a new seperator plate from gmpartsdirect.com.
FYI for anyone needing this part, if you have 6YP stamped on your transmission the part # is 8654482.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
