What else is needed for a 200C auto to a T-56
Old Aug 7, 2002 | 10:27 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I have been researching this for some time. These are all the parts I have discovered I need so far.
Parts Needed From where
·T-56 with flywheel and clutch Junkyard
·T-5 bell housing Junkyard
·Adapter plate Sallee Chevy
·Energy Suspension Polyurethane Transmission Mount Summit/Jegs
·Roller pilot bearing Summit/Jegs
·Rear main seal Summit/Jegs
·Spohn Crossmember Found here for $100 http://www.fasttoys.net/8292fbodytrans.html
·T5 torque arm Junkyard
·Universal Speedometer Signal Interface Dakota Digital
·Vehicle speed sensor Dealer
·Electronic Speedometer carparts.com
·T-56 pedal Assembly Junkyard
·T56 master/slave cylinder assembly Junkyard
Anything else?
If you have done a swamp like this or know alot about it can you pm me or reply to give me more info about it.
I am not sure if a torque arm from a T5 will work. Does anyone know?
Old Aug 8, 2002 | 06:55 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Here are the sites I have been getting info from.
http://www.drivetrain.com/transmanualT56.html
http://www.z28.com/installations/trannyconvert.html (Very helpful)
http://www.sallee-chevrolet.com/Borg...bwt56pics.html
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
cRoe4
Aug 7, 2015 08:46 PM
