Rear end Clunking
Old Jul 4, 2002 | 09:02 PM
91zeder's Avatar
Rear end Clunking
After driving for a while when I go to back the car into a parking spot(backing or driving very slow and turning at same time) my rear end (posi with 273 gears) makes awful clunking sounds.
Is this normal or is there something wrong?
Old Jul 5, 2002 | 03:06 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Put one or two bottles of GM Posi Additive in with gear oil.
Old Jul 7, 2002 | 10:40 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sure it's not a broken tranny mount?
Old Jul 7, 2002 | 11:03 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
mine does it too, he needs to add the gm diff additive, mine didn't start doing it untill i changed fluid, and on suggestion from a friend used a full synthetic fluid that claimed i wouldn't need the additive,
and i know my torque arm and trans mounts are good, cuz that was my first thought too
Old Jul 7, 2002 | 09:29 PM
32789RS's Avatar
Mine does the same thing but it's only noticed at low speeds or while turning at low speeds, I changed my fluid twice and added posi additive, both times and still does it. any thoughts on this?
Old Jul 28, 2002 | 07:47 PM
pontiacZ28's Avatar
Maybe the clutches in your posi are blown, that could make the clunking sound since the clutches are also like shims and when they get worn down it gives play between your axle and the c clip. The additive is a for friction and that could cause it but you would have to have a lot of friction back there for it to make sounds like that.
Old Jul 29, 2002 | 12:54 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
MY car does that after i added an auburn posi unit and 3:73 gears
it make a horrible banging noise when i start out slow and when i turn slow.Once pick up speed it goes away.When it bangs you can definatly feel it.You get loud thunk sound and it does come the rear.........
Old Jul 30, 2002 | 10:07 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Any other ideas what it could be????????
Old Jul 30, 2002 | 10:58 AM
MdFormula350's Avatar
do u hae enough fluid in the rear, and u need posi additive also.
i have never done a rear gear swap but it is possible that maybe something is lose or put on wrong. I had to change a front bearning on my moms chevy astro van and i put everything back on right and tighten everything but now i have a wine in the rear at any speed. I know its put in right but it just makes a noise now!
o well not my car
Old Aug 8, 2002 | 08:22 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Heres a update i changed the fluid in my rear end(MOBIL 1 and POSI ADDITIVE) and the clunking stopped in the rear end
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
