having problems with 460LE
Old Aug 13, 2002 | 06:47 PM
worldofool's Avatar
I rebuilt a 460LE and right when I start driving it starts to slip from 2nd two 3rd all the other gears are fine. I took it apart and put it togther again and it did the same thing. Anybody tried to rebuild a 460LE and have these problems.
Thanx
Old Aug 14, 2002 | 02:48 AM
transfixleo's Avatar
Slips through 2nd? Let's see: Torn Teflon seal on the 2nd Servo Piston, worn out 2nd Accumulator Piston/seals, loose Accumulator Housing, warped Reverse Drum, improper pressure response, sticking Accumulator Valve in VB, VB Gasket problem, etc.
Old Aug 14, 2002 | 07:31 PM
4L60bliss's Avatar
OK, lets start this thread off on the right foot.
A: What was originally wrong w/ the tranny that prompted the "rebuild".
B: List everything that the rebuild consisted of: (i.e. replaced all clutches w/ Allomatics, replaced all seals, installed shift kit, etc...)
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
