Gear ratio numbers
Old Aug 17, 2002 | 07:02 PM
Bebefouch's Avatar
Gear ratio numbers
I was wondering if anyone had a link to a site which shows the ratio of every gear in every tranny that was available in a 3rd gen f-body. I remember nastyz28.com had it but their 3rdgen section was closed down a long time ago. Any help is here appreciated, thank you.
Old Aug 18, 2002 | 12:05 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
as fot the 700r4 it was 3.06/1.63/1.00/0.70
th400 is 2.48/1.48/1.00
t-5 is 2.95/1.94/1.34/1.00/0.63
i know the 82 and 83 came with 4 speed manual but i cant recall there ratios
hope this helps
Old Aug 18, 2002 | 01:07 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
this site has them in the tech section, or something
Old Aug 18, 2002 | 03:41 PM
Bebefouch's Avatar
I was aware of that but they do not cover the years 89-92. Thanks anyways though .
Old Aug 18, 2002 | 05:40 PM
jerflash's Avatar
what i have writen there is right
those are the only trans offered in third gens
Old Aug 20, 2002 | 11:22 AM
flyin89's Avatar
Actually I have read that the TPI and TBI trans(5spd) had different gearsets in the trans! I'll check and find the source.
Old Aug 20, 2002 | 11:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is correct. At least, 5th is different, that much I know for sure. The low-perf models had .63 5th (L03 and I think LG4), the high perf (L69 & LB9) were .76. 1st is 2.95. I don't fool around with LG4 or L03 stuff if I can help it so I don't know about the rest of them; listings I've seen for countergears and such would indicate they're the same though. The 6-cyl and 4-cyl cars got a different countergear & clutch gear, with wider ratios, something like about 3.30 1st gear.
Old Aug 20, 2002 | 11:58 AM
Car: 1984 Firebird
Axle/Gears: 4.10
4 cylinder cars had 3.76 first gear in their t5s.i'm gonna see how long it takes to break it :lala:
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
