difference between dana 44 and 9 bolt?
Old Aug 19, 2002 | 02:50 PM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
The guys at moser need me to actually measure my axle unless I am really sure what I have because they have the stock measurements.
They say camaro came with 9 bolt and also dana 44. I am sure I have the borg warner 7.75" ring gear axle with 2.77 because it's casted into the diff housing.
I just wanted to make sure what I have because I don't want to pull out the axle again. What's the difference between these too rear ends?
Old Aug 19, 2002 | 02:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, a B-w axle is made by B-W and has their name on it, and the Dana is made by Dana and has their name on it.
So, if you have a rear with B-W on it, the odds are pretty good it's a B-W. Good enough in fact to order stuff on that basis (unlike GM's production-line "codes"). I'd tell them you're sure, and go ahead and send your stuff.
Old Aug 19, 2002 | 03:08 PM
LT1guy's Avatar
Car: 1987 Trans Am
Unless you have a Firehawk or Turbo TA, or someone replaced the rear, its unlikely you have a Dana 44. Its usually the lowly 10 bolt 71/2 /7 5/8 .
Old Aug 19, 2002 | 07:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Look at the back cover..
10 bolt 7.5/7.625" has a smooth cover and 10 bolts holding it on.
9 bolt 7.75" has a rubber plug in the cover and has 9 bolts holding it on.
Dana 44 8.5" (very rare) has a metal plug in the cover and has 10 bolts holding it on.
Old Aug 19, 2002 | 11:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The Dana can also be recognized by the asymmetric shape of its cover.
evilstuie
Jan 9, 2020 08:29 PM
sailtexas186548
Jan 19, 2016 12:21 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
