TV Boost Valve.... (?!)
Old Aug 22, 2002 | 08:26 AM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
Can someone explain what this is supposed to do..? I see .471" and .500" ones advertised, but I'm not sure what they do, and if bigger really IS better in this case?
Old Aug 22, 2002 | 11:40 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The larger the # the more line pressure there is, creating firmer shifts.
However, most tranny guys will say on most str applications to go with the .471 boost valve.
Old Aug 22, 2002 | 01:29 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Hey Ken. I've got a .500 main boost valve and a .283 reverse boost valve. When I had the B&M shift kit it was painful, but with the TransGo shift kit it's very liveable on the street.
I would get the bigger valves now because you know you're gonna want them later
Old Aug 22, 2002 | 07:21 PM
4L60bliss's Avatar
.471" is the largest GM makes. .500 is aftermarket. The .500 boost valve is pretty much as high as you want to go. I have seen up to .577" and that is just overkill. You want the tranny to shift firm, not bang into the gears.
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
