3/4 upshift sleeve/valve in valve body
Old Aug 23, 2002 | 12:41 PM
Dragula's Avatar
Which one is this when looking at it from underneath? I replaced this valve in my 700r4, but now we will be doing my buddies and I can't remember which one it is.
For some reason (without having a picture) I am thinking it is at the front of the valve body, closest one to the passenger side.
Any insight?
Old Aug 23, 2002 | 06:24 PM
4L60bliss's Avatar
Do you have the GM "shift correction package" or do you have the Superior "upshift sleeve"? It makes a difference.
The GM kit replaces the 3-4 valvetrain. The Superior sleeve replaced the TV sleeve. If it is the Superior sleeve, then its the valve all the way on the right hand (passenger) side. You'll need to remove the TV linkage to remove the roll pin and if memory serves me, you might have to remove the Auxillary Valvebody to provide clearance. Never done them in the car, only while all apart... Sorry.
Old Aug 26, 2002 | 06:54 AM
Dragula's Avatar
It's not the TV plunger like B&M sells......it's the GM police interceptor 3-4 sleeve and plunger.
Old Aug 26, 2002 | 10:19 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The 3-4 TV valve and the 3-4 shift valve, along with the sleeve, reside in the same bore of the Valve Body and are in the third bore from the left on the front of the VB as you are looking up at the VB from under the car while it is mounted on the transmission (left = driver side, technically the fourth bore if you count the manual valve but that one is in a seperate area).
Old Aug 27, 2002 | 06:53 AM
Dragula's Avatar
Cool....I was right....is on the front, closest to the passenger side.
Thanks guys.
Old Aug 27, 2002 | 12:01 PM
Matt87GTA's Avatar
Yeah... I guess it would be better put that way, but technically there are two more smaller valves on the passenger side that are closer to the passenger side than the 3-4 stuff, and some VBs have another bore between those two and the 3-4 stuff (I forget what it is for, but usually is just plugged) so I wanted to try to convey that.
Old Aug 27, 2002 | 02:29 PM
Dragula's Avatar
Not a problem...thansk for the input. I think I remember the others also, except aren't they smaller in size?
Can't remember......at least I am hooked up for the valve change.
Old Aug 27, 2002 | 07:07 PM
4L60bliss's Avatar
The Superior kit does not replace the 3-4 TV Sleeve, it replaces the TV sleeve, where the plunger resides. The GM kit actually replaces the 3-4 valvetrain.
Old Jun 4, 2003 | 02:55 PM
25THRSS's Avatar
Which is better?
LT1Formula
20
Nov 14, 2015 12:02 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
1985chevydude
Aug 20, 2015 12:29 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
