th350 swap questions
Old Aug 28, 2002 | 04:56 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ok, ,my 9 inch tailshaft TH350 is arriving tonite...........what various cables and what not do i need to install it?
how do i change the speedometer gears?
what kinda kickdown cable do i need?
where can i buy new trans cool lines?
where do i take the vacuum from for the modulator? the carb or the manifold?
can i use my 700R4 shifter for now?
can i use the 700R4 shift cable?
how do i adjust the kickdown cable?
where do i hook the reverse lights?
will the torque converter that comes with it work with the 700R4 flexplate?
how hard is it to install a shift kit?
please excuse my little knowledge when it comes to automatic transmissions
thanx
Old Aug 28, 2002 | 08:24 AM
ede's Avatar
ede
Re: th350 swap questions
A: i think only the driven gear needs changed, it slips off the square drive end of the cable
A: you need one from a th350
A: any parts store, they won't be prebent. even from gm parts they aren't
A: manifold
A: maybe
A: good chance
A: it's not adjustable
A: should already be hooked up to the 700r4 shifter
A: yes
A: not real hard and if you need a kick down cable you'll be right there any way
A: i don't know anything either and the only stupid question is the one that goes unasked, but we sure do have fun with some of the ones that get asked
thanx [/B][/QUOTE]
Old Aug 28, 2002 | 03:48 PM
thanx dude
Old Aug 28, 2002 | 04:05 PM
b9radz's Avatar
How are you mounting your torque arm ?
Old Aug 28, 2002 | 07:31 PM
hurst and B&M make a kit................the bracket looks like it attach in between the tailshaft and main body of the tranny
well, my 350 engine and TH350 arrived, i'll prolly put the TH350 in, in 2 weeks
Old Aug 28, 2002 | 07:34 PM
ede's Avatar
ede
the adapter goes on the outside of the tail houseing, not between it and the main body. it's pretty easy after you have the kit.
Old Aug 28, 2002 | 10:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The kickdown (detent) cable is adjustable but not in the same way the 700R4's TV cable is.
There's a lock on the cable that attaches to the bracket up at the carb. You unlock it and push the cable back through a bit. Move the throttle to WOT and push the lock down. The cable will click as the throttle is moved to WOT. Release the throttle and the detent cable is now set.
It's kind of hard to describe how the lock works. It's better to just see it.
Old Aug 29, 2002 | 04:04 AM
hehe, i lucked out.....the motor and trans still have the kickdown cable on it one less part i have to buy
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
