shifting problem
Old Aug 28, 2002 | 08:17 PM
regchamp's Avatar
shifting problem
Hi, I have an 84 Z28 that I converted over to a th-350. At full throttle it shifts at about 3800 rpms, it should be shifting at about 5500. I just put in a new vaccuum modulator and I have it running off of a vaccuum plug in behind the carburetor on the intake manifold. I know that the vac modulator controls upshifts and the kickdown cable controls downshifts. My kickdown/detent/TV (whatever it is called) cable is not hooked up, I have a new bracket ordered for it that I am waiting for. Would this do it? I just put the tranny in, so I dont' know how it acted before. I also have a very large cam in the car, with about a 489 lift, and I the convertor stalls around 1800 rpms when the brake is held down and I give it gas. Any recommendations on how to get it to shift at higher points? Also, it WILL shift whenever I want it to if I do it manually, I just want it to shift normally when in drive. Thank you
Old Aug 29, 2002 | 07:04 PM
regchamp's Avatar
bump
Old Aug 30, 2002 | 05:09 AM
Pro Built Automatics's Avatar
Install the Trans-Go Performance Shift kit & this will address the WOT low rpm upshift problem besides firming up 1-2 & 2-3 WOT shifts.
Old Sep 1, 2002 | 03:59 AM
transfixleo's Avatar
To change the WOT shift points you will need to recalibrate the Governor. B&M sells a nice kit just for that.
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
