B&M Ripper for Aftermarket T-56, fit problem
Old Aug 30, 2002 | 05:54 PM
170412's Avatar
Hi,
I have an 88 IROC with a Universal T56 transplant. Car was
originally a T-5. Just installed a B&M Ripper PN 45053 for the
universal T56. The shift lever now sits so far to the right I
can't use rightmost gears after reassembling console.
As the lever is not a bolt on I am considering having it cut
and rewelded at a better angle but wanted to see what others
have done.
Any one out there have a better solution? different shifter?
console mods?
Thanks,
Jim
Old Aug 30, 2002 | 06:20 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
A good idea would be to call the company who built the tranny.
Old Aug 30, 2002 | 06:42 PM
Tom Keliher's Avatar
Got any pictures of how it looks in there?
Old Aug 31, 2002 | 04:33 PM
170412's Avatar
Tom,
I have a picture I can send but have not been able
to figure out how to do it through the message
board.
What I can tell you is that the shifter appears to be
designed for a transmission which is roatated sligtly
towards the driver side of car as it would be in a stock
4th gen. The universal T56 sits straight up so lever is
off to the right. I would guess offhand your firebird
would have the same problem I am having. The shifter
also sits much lower. The **** barely clears the top
of the center console but seems to be high enough.
Since it seems to be the only alternative to the stock
shifter that I have found I will probably go to a machine
shop and have the lever cut and re-welded.
I will post pictures if I ever figure out how.
Jim
Old Aug 31, 2002 | 05:49 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
See where is says Attach file:? Click browse and find the picture saved on you pc.
Old Aug 31, 2002 | 06:37 PM
170412's Avatar
Tried the attatch image once before and it didn't seem
to work but here it goes again.
Pictures are of trans in neutral position.
Old Aug 31, 2002 | 06:54 PM
Did your shifter look like this? Here is the left side view:
Here is the view looking directly at the front:
Check your e-mail
Old Sep 1, 2002 | 12:05 PM
OK, here are the pic's of his shifter intalled in his Camaro. Sucks, this shifter is way off for a 3rd gen. I don't understand, as the "aftermarket T-56" is designed specifically and wholly to replace a T-5 in a 3rd gen Camaro. So why does B&M market a specific P/N for the "Aftermarket T-56" when it doesn't properly fit a Camaro?
Here is the top view:
Here is a side view:
Thanks for the pic's, Jim!
Old Sep 26, 2002 | 06:46 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Most likely that shifter is actually for a Mustang t-5. All those t-5's are straight up.
Old Sep 26, 2002 | 08:14 AM
Ringmaster72's Avatar
Car: 1989 IROC
I have the Ripper in my 89 with a T-56. It came with the transmission, so you should just use the part number for a 4th gen camaro and it will fit fine. Mine goes up a little, then curves toward the driver side. It is in perfect position.
Tim
Old Sep 26, 2002 | 05:54 PM
1PTR315's Avatar
The stock t-5 shifter has the correct base but the 18* bend to the right makes it hit hard. I just put a aftermarket t-56 in my 87 IROC. I bent an old Hurst indy handle and attached it to the shifter base that came with the trans about 18* left and opened the bolt holes so I could lean it back about the same amount. Works perfect. Hieght and position are perfect. The 93+ t-56 shifter WON'T fit. Mine is on the way back to jegs now. b&m lists a shifter for this but they did not do thier homework cause they send a ford shifter. It mounts to the trans but barely sticks out of the console. The closest thing I could find when I still wanted a short throw was the t-5 base with a 93+ handle from hurst. It should fit real close but hurst won't sell both parts together. You can buy the t-5 shifter from whoever and send them the incorect handle and they will trade you for the t-56 handle from a 93+. Put the 2 together and you will have a hurst billet shifter that is in the right position and 1/2 inch taller. This aftermarket t-56 is not well planned and if I had it to do again, I wouldn't. By the time I got it on the road I was 3 grand out for an extra gear between 4th and 6th. It was a real cool idea till I went through all this crap just to get it in the car.
Old Sep 26, 2002 | 09:03 PM
Berlinetta's Avatar
I saw some of you guys are running 383's with a T-56. Where did you get your flywheel? I cant find one that will work with the aftermarket T-56/383 setup.
Old Sep 30, 2002 | 06:24 AM
Hayes billit from Summiit racing equipment, for 1pc. rear main seal.
Great price too. Can't remember to part number though.
92camaroJoe
Jul 29, 2023 07:57 PM
Street Lethal
Apr 30, 2019 12:14 PM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
cRoe4
Aug 7, 2015 08:46 PM
