Which Steel Driveshaft?
Car: 86 Iroc-Z28
Engine: FB385
Hey, i was wondering if you guys could direct me to a great driveshaft! I am looking at steel since my engine already is around 450hp and i heard that aluminum ones do not last long after that. I plan on getting the motor "stroked" in the future or some type of forced induction. I only want to replace the driveshaft with one that will take a lot of abuse! Any help would be greatly appreciated. Any personal refferences too, thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You get one custom made from 3" x .083" wall tubing. Also get it made with 1350 series yokes.
Any good driveline shop should be able to make one in less than a day.
You'll need to get a 1350 series yoke for the transmission and differential. From what I've been told either S10's or Astro vans have 1350 series yokes.
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Check out a company called Denny's Driveshafts. They have many lines for different levels of power and are reasonably priced.
Car: 87 IROC L98
When you look at the smaller u-joint, usually a 1310 series against a 1350 series, you'll understand why everyone blows out the smaller u-joint under high HP.
Upgrading the u-joints is just more insurance against losing the driveshaft investment.
You can buy nice aftermarket billet yokes but unless you start pushing over 700 hp, the factory ones will work fine. Just buy aftermarket u-joint straps.
Car: 86 Iroc-Z28
Engine: FB385
Thank you Stephen, if the place that i get the driveshaft from does not inform me of this i will definately look into it! Thanks again for the info-Bryan
3rdgenparts
May 21, 2016 11:50 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
