Convertor Question
Old Sep 3, 2002 | 06:52 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Convertor Question
How can I tell when the convertor is seated properly inside the transmission. I thought once installed correctly the tailshaft will spin at the back of the transmission?
Old Sep 3, 2002 | 07:32 PM
4L60bliss's Avatar
Nope, not at all. First of all, if the tranny is out of the car, then obviously, none of the clutches are applied, so the output shaft won't turn.
Second, its not the input shaft that people don't usually get engaged, its the pump rotor. If you lay a board across teh bellhousing, there should be like 2" between teh board and the TC (I don't remember right off hand the exact measurement). Or you can try and fit your finger between the TC and the pump (front of the tranny) If you have a fat finger like mine, it might not fit.
Old Sep 3, 2002 | 08:01 PM
DTL504's Avatar
Thanks, thats just the answer that I was looking for. i tried putting my finger between the converter and it did not fit.
Once again
Thanks: Dave
84z96L31vortec
Aug 20, 2017 12:16 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
