s 10 posi???????
Old Sep 7, 2002 | 03:17 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
s 10 posi???????
anyone know if a s 10 posi will work on a 3rd gen?........ im not sure of the spline counts on the posi i know i have 28 spline axles so if anyone knows i appreciat the help!!!!!
Old Sep 7, 2002 | 07:00 PM
ede's Avatar
ede
yeah it'll work, make sure you have same series geras or swap the gears too and count the splines so you get what you have, or buy what you need.
Old Sep 7, 2002 | 07:59 PM
Car: '88 GTA
Engine: L-98
thanks!:hail: :hail: :hail: :hail:
Old Sep 8, 2002 | 02:07 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
why is it a good idea to put the s10 posi in it is it stroner or is it the same just cheaper?
Old Sep 8, 2002 | 03:29 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Same, sometimes just cheaper at the wrecker.
Old Sep 8, 2002 | 06:49 AM
4L60bliss's Avatar
S-10s should have the Eaton Locker, wich is not ideal for race applications.
Old Sep 8, 2002 | 09:05 AM
Car: '88 GTA
Engine: L-98
well i was at a swap meet yesterday, i picked up a posi srom an s 10 for 50 bucks and its in good shape....... so ill probably go and get some 6cyl. gears from the junkyard and slap it together
Old Sep 8, 2002 | 10:34 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
I had that Eaton POS in my Blazer till the gov lock mechanism locked and would not unlock. I replaced it with an Auburn. If you're at a wracking yard you may as well try to find a low mileage unit from a 3rd or 4th gen. You still need to replace bearings and check for the R & P set up.
Old Sep 8, 2002 | 11:40 PM
Engine: 305-4v
When Chevy Hi Performance did their "My Generation Camaro" series, they used both a set of 3.73s and posi from an S10. I don't know what type of posi it was, but they just rebuilt it and voila!
Old Sep 10, 2002 | 03:03 PM
92BLKL98's Avatar
According to the shop I bought my Auburn from it would be more expensive to rebuild the Eaton than to buy a complete Auburn. Plus I like the Auburn dessign better it is locked unless it needs to slip, the Eaton is unlocked until it detects 100rpm difference in right to left wheel speed. The Auburn is much simpler idea remember the KISS principal Keep It Simple Stupid.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
