T-56 + Hp
Old Sep 10, 2002 | 09:13 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
T-56 + Hp
How much HP do you think a t-56 with heavy duty clutch can take? i plan on building another camaro soon with either a 383 or 400/T-56 combo...
thanks,
dave
Old Sep 10, 2002 | 09:37 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I think torque plays a bigger factor as far as trannies go. A '93 T-56 can handle around 400 ft-lbs, while '94-up can withstand 450 ft-lbs.
Old Sep 10, 2002 | 09:42 PM
87RS402's Avatar
a T-56 can take more hp than you'll ever realisticly throw at it, but only about 450ft-lbs of torque.
Torque is what breaks things, hp is only a measurement of torque.
Old Sep 10, 2002 | 09:43 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
A 94 - 97 T-56 is rated at about 450hp/450ft lbs torque. I'm pushing a little over that with my combo with no problems. A '93 T-56 is rated at a little less than above specs but it has a steeper first gear and better over all gear ratio's. I would'nt recommend using a LS-1 T-56 unless you are swapping in an LS-1. It's the torque that will kill a tranny faster, just keep that in mind. Hope this helps.
Mike (1bad91Z)
Old Sep 10, 2002 | 10:05 PM
Engine: 350 CID
thanks alot guys....from the looks of it i guess im either gonna go with a built up 350 or just a 383 with a nice lumpy cam..either way it should be a pretty sweet car
Old Sep 13, 2002 | 08:57 AM
83 MidniteZ's Avatar
Aftermarket T56s have the steeper gears like the 93 camaro, but is also rated at 450ft/lbs
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
'91 Formula
Nov 25, 2001 04:58 PM
