Shift Kits
Old Sep 10, 2002 | 10:16 PM
Firl's Avatar
Shift Kits
How much does a shift kit improve the shifting? And is their any you guys would recomend?
Old Sep 11, 2002 | 12:13 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
On a stock trans you will get a big improvement.
Transgo is the best..........
Do a search.......
Old Sep 11, 2002 | 01:19 AM
Firl's Avatar
Looks like that will be on my list of things to get now, now the hard decision is which should come first ... paint job ... or shift kit, im thinking the shift kit
Old Sep 11, 2002 | 08:12 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
go for the go and forget the show
Old Sep 12, 2002 | 12:07 AM
burnouts4ever's Avatar
how much faster would my car be with a shift kit, vs not having one?? I have the L03 engine and open element air cleaner... I need a transmission rebuild and torque converter, does a hi stall converter really improve performance alot?
Old Sep 12, 2002 | 12:12 AM
87transam5.7tpi's Avatar
ya i"m interested in if a shift kit helps alot. I'll install one this weekend just to curve my apetite. I know the stall does help alot though. Jusy a FYI
Old Sep 12, 2002 | 01:09 AM
87Formula4bbl's Avatar
Car: '87 Formula
Shift kit is also on my list of to-do's. From what I've read on here, your probably going to want to go with the Trans-Go, that's what I'm gonna go with. As for gains, you might get a tenth or so, but it's probably not going to be much more than that.
Old Sep 12, 2002 | 12:38 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i had one on my 89 rs. it was nice. i installed it my self. it was pretty easy, with the video. Trans-go is the way to go. the B&M kit doesn't fix problems with our trannys. the transgo does. i was able to chirp 2nd every time. and 3rd would just jump forward. it was a big improvement over the stock shifting.
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i also but a B&M tranny cooler on. and a polyurethane tranny mount. the rubber one wont hold up to a hard shifting tranny.
Old Sep 20, 2002 | 11:45 PM
caleb's Avatar
Car: 89' Iroc
where did you mount the trani cooler?
Old Sep 21, 2002 | 01:55 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i mounted it on the front of my radiator. it comes with straps that hold it there.
Old Sep 21, 2002 | 05:27 AM
sweet82z28's Avatar
I am also thinking about a shift kit, but I don't know if it would help me much in my quarter times because I already have problems with the tires spinning between 1st and 2nd. I usually get a good bark, and sometimes backend sideways movements, so would a shift kit be a good idea or not?
Old Sep 21, 2002 | 06:11 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
sure. but you could also try some new rear control arms, panhard rod, tires, and any other traction improvement options.
Old Sep 22, 2002 | 12:24 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i would say go with the trans go shift kit
i got the B&M shift improver kit and it just made my tranny worse.....yah it will chirp in second....but if i try to manual go through the gears it will rev up really high like its in neutral when i shift.........the directoins said not to put it on a old worn out tranny.........i learned my lesson
Old Sep 22, 2002 | 03:03 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I just put a Transgo in my car a couple weeks ago and my trans in not working right anymore. I have gone through it and takin it back apart 3 times and I still have problems
1) It starts off in 2nd gear and will not downshift into 1st
2) Holds 2nd gear waaay to long (redline)
3) Will not downshift from 4th to 3rd when travelling 60+ MPH
My trans worked perfectly before the install. Transgo has been helpful on trying to solve my problems but nothing has worked. I am going to replace my new autozone filter with a new GM filter, kinda the last hope. I think its time to get a T-56.
I regret getting it bigtime. Can't even sell the tans now, except maybe as a core
Old Sep 22, 2002 | 05:36 PM
86Z28350's Avatar
Reply to 92RSshearn
Are you running the TPI on it? (I don't know about the TBI or MPFI.) If you are, try playing with your TV or throttle valve Cable. I have found that if it is not adjusted properly you'll never kick down to passing gear, you'll redline before shifting, won't shift at all, or you have to let off the gas to get it to shift. I actually played with it to try to improve my shift points and really got it messed up. Mark where it is now if, especially if it is still in the stock position. It may need a little tweaking since you changed the way the tranny's fluid flows and the way it shifts.
Old Sep 22, 2002 | 06:07 PM
Car: 92' RS
Engine: LO3
I am running with a TBI. I have redone the TV 3 times and nothing has changed. I set it according to transgo's instructions.
Old Sep 22, 2002 | 11:51 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
How did you set the detent cable? Did you open the throttle all the way eith your hand or did you use the pedal to open it up? I think i moght be having the same problem with my 700.
Old Sep 23, 2002 | 12:17 AM
Car: 92' RS
Engine: LO3
The detent spring, you just have to bolt it up, no particular spot, it will settle itself out.
Well, I guess I'm not the only one
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
