throw out bearing R&R
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i will pulling my motor out soon and im gonna pull the trans with it...im gonna put a clutch in it as well as a well as doin a throwout bearing.....
my question is...how do i do this? any special toos required and were do u get them....
thanks for the help
"crazy"
thanks for the help
"crazy"
you'll need a clutch alignment tool. a lot of the clutch kits comes with a plastic one. do the clutch, throw out bearing, preasure plate and pilot bearing. you'll need a puller for the pilot bearing.
Engine: CARBED LT4
Transmission: MK6
thanks ede....is it hard to do and how long should it take?
the kit i was looking at was the centerforce stage 2...it comes with a pressure plate throw out bearing and clutch disc...and with an alignment tool....how much is a pilot bearing?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Get the roller pilot bearing instead of the stock bushing.
Moroso makes them (among others).
Moroso Part# 41100, $14.95 at Summit.
http://moroso.com/catalog/categorydi...?CatCode=24003
-Rich-
-Rich-
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
get a pilot bearing puller and a slide hammer. i got the tools from auto zone by just putting down a deposit, 40 bucks. the puller didnt fit into my pilot bearing but luckily for me it was so worn that it just fell out. but your going to need the slide hammer to help pull it out and install the new one.. i just did all this last weekend and the only problems i ran into was loosening the trans bolts and then getting the trans back in. tricky lining it up right. your gonna need an angle attachment to get to the clutch cover bolts and you probably gonna want to replace the clutch fork and clutch fork ball stud if it looks worn. good luck and have plenty of beer on hand..
pilot bearing/bushing
If it's a pilot bushing you do not need a puller. Insert some white grease with your finger behind the pilot bushing then take an alignment tool or something of the same size as the inside diameter of the bushing and tap it in the hole. The force of the grease will push the bushing/bearing out. I've changed many manual trans and never needed a puller or a slide hammer.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I'm curious here. How can you tell if the pilot bearing needs to be replaced? Would it whine?
Engine: CARBED LT4
Transmission: MK6
how long should it take for the first timer.?...from time the trans it out (with the motor)....to get the clutch pressure plate throw out bearing and pilot bearing...get it all reassembled and attatch it back to the motor....i dont want to mess anything up so detailed instruction are very welcome
thank guys
thank guys
Former Sponsor
Car: 1992 Camaro RS
I know it should be replaced when replacing the clutch as a sort of preventative maintenance. The reason I ask is because since my tranny swap, I now have a whine. It gets louder when I press the clutch pedal, but it also whines a bit without depressing the pedal unless I'm at a low rpm. At around 1700 rpm and up, it whines. I've been meaning to replace the throwout and pilot bearings, but I haven't had time. The pilot bearing is new, but the throwout bearing was used (T56, so its like $100).
Anyway, I plan on replacing both just to be safe, but do these sypmtoms sound like the throwout bearing...or the pilot?
Sure sounds like the throwout bearing to me as well. It might be that the bearing is making contact when it's not intended to. First try to adjust the clutch fork so the bearing is farther away from the disc. See if that works. Why would you use a used throwout bearing? I think you said they were 100.00 But if you have the 10.5 inch clutch you can buy a new pressure plate clutch disc throwout bearing and pilot bushing for 150.00
Your better getting all new parts instead of rebuilt considering the amount of work that is involved.
