Do you have to replace the clip on the clutch pedal?
Old Oct 3, 2002 | 12:13 PM
Mike89GTA's Avatar
Hey, I'm attempting to put my clutch hydraulics back in, except I can't get them to stay on the clutch pedal. It looks like the clip that's on the end of the piston might have broken. Am I supposed to replace it after removing the hydraulics? It's so hard to see because it's up in the dash, so I'm not sure why it's not snapping on, but I think it might have broken when I took it off.
In this picture it's inside the loop at the end of #4.
Old Oct 3, 2002 | 02:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It comes with new hydraulics...
I guess if your is broken or won't hold on for whatever reason, you have to replace it. It's possible to take the system apart without breaking it, but an old one might be hard to disturb without it falling to pieces.
Old Oct 3, 2002 | 06:48 PM
Mike89GTA's Avatar
Thanks, I just ordered a new clip. Glad they sell it separately
Old Oct 3, 2002 | 09:45 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
FYI, GM says to replace those things on the brake and clutch rods any and every time they are removed. Safety thing......
Old Feb 3, 2006 | 01:03 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i need new bushings for the clutch pedal like you needed and bushings for both brake and clutch pedals to control the side to side play. and one for the brake pedal to connect it to the brake booster while im at it.
does anyone have any part numbers?
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
