Is it suppose to do that?
Old Oct 10, 2002 | 08:37 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
I need to know if this is normal or is something wrong with my gear box. Its a 700r4. When the stick is in the DRIVE position letting the gas go feels like its in neutral, but when the stick is on the 3-rd gear position letting the gas go feels like in a manual transmission car (stronger deacceleration)!
Thanks for any help!
Old Oct 10, 2002 | 11:58 AM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
that's normal... when u let off the gas in D it's most likely in OD, so it barely has any RPMs, it 3'rd it'll be at higher rpms ans slow you down.
Old Oct 10, 2002 | 05:33 PM
breathment's Avatar
that and the Torque convertor i think locks up more in D then when OD. im not sure though.. same as when putting it in 2nd..
Old Oct 11, 2002 | 01:26 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Thanks! I was starting to get afraid that my gear box is starting to go again! These things are not cheap to fix!:lala:
Old Oct 11, 2002 | 10:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Actually I think it has something to do with there being no overrun clutch when the manual shaft is in OD so there's no engine braking regardless of what gear the transmission is actually in.
Old Oct 11, 2002 | 07:06 PM
4L60bliss's Avatar
Yes, what Aperion said. DRIVE is 3rd gear. I belive you are refering to OverDrive. When its in Overdrive, there is no engine-braking. If you put it down into Drive, 2nd, or 1st, the overrun clutches apply (to prevent forward sprag overrun) and cause engine braking.
Old Oct 12, 2002 | 11:51 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
So, the engine breaking isnt doing any harm to the tranny?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
KO1
16
Oct 15, 2015 05:00 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
