Tranny Mounts?
Old Oct 18, 2002 | 05:30 PM
86IROC350NY's Avatar
Tranny Mounts?
I have noticed that my shifter shakes when the car is on. I am thinking it is the tranny mounts. Are thay hard to replace? I am just wondering if i need to have a shop do it.
Anyone know how much for parts and labor?
--Dan
Old Oct 18, 2002 | 08:58 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
An Energy Suspension mount from Summit is about $20. It's not hard to do yourself; if you get it done, I would say they should only charge 0.5 hr labor.
Old Oct 18, 2002 | 09:38 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
It isn't hard to replace a tranny mount. All you have to do is put the front wheels of the car on drive up ramps and secure the back wheels with wheel stops. Put a jack under the tranny with a block of wood in between (so you don't damage the tranny), then take off the nut that holds the tranny to the crossmember on the car. Jack up the tranny till you can remove all bolts that hold the mount to the tranny and replace with whatever mount you want. Attach the mount with the nutsfrom the old one, lower the jack and replace the crossmember nut, and your done.
I did mine in about two hours with almost no complications. The Hayes manuel is a good source for these kinds of repairs.
Old Oct 19, 2002 | 06:43 PM
MdFormula350's Avatar
do it your self, does not take that long..
heres a good one to get
http://www.slponline.com/view_produc...RTNUMBER=60005
Old Oct 20, 2002 | 01:15 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
whats? 2 hours? it took me about 20 mins said and done. i could take a tranny out in less then an hour
Old Oct 20, 2002 | 03:39 PM
Just for the record
I have never heard of Cinnaminson NJ
Old Oct 20, 2002 | 05:08 PM
Car: 89 Formula
Engine: Carbed 5.7
well i have never heard of closter. lol
Old Oct 21, 2002 | 10:15 PM
knoxbonnie's Avatar
Maybe someone else has had better luck with it than me, but I had severe vibration problems from a poly trans mount. I changed it back to a new stock rubber trans mount, and I had no more vibration problems.
Just my 2 cents.
Old Oct 22, 2002 | 10:14 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have had my ES mount in for 2 years, and never had a vibration problem :shug:
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
