everybody with TCI 700 tranny, need help inside!
Old Oct 22, 2002 | 02:26 PM
holmes677's Avatar
i just put a 700 TCI streetfighter transmission in my 86 305 tpi Z. Everything is bolted up, but just when i thought i was done, i noticed a little plastic piece on the right side of the tranny if you are looking at it from the converter standpoint. The piece has 2 wires coming from it and a vaccumn hose leading from it as well. does anybody out there have the same tranny and know where these wires/ hose should go?
Old Oct 22, 2002 | 08:30 PM
holmes677's Avatar
does anybody have an idea, im really confused here
Old Oct 22, 2002 | 09:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take a look at:
http://www.tciauto.com/instructions/376600_inst.htm
Old Oct 25, 2002 | 11:20 AM
holmes677's Avatar
thanks for the info, but it doesnt say where the vaccumn hose leading from it goes, im new to working on cars so i appreciate all the help i can get.
Old Oct 25, 2002 | 12:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Did you read it?
Originally posted by holmes677
"Connect the vacuum switch to a ported vacuum source on the carburetor or throttle body. (If you find that the TCC operation is erratic in your application, then you may try moving the vacuum source to the manifold.)"
Linson
Oct 24, 2025 02:00 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
bjpotter
Oct 4, 2015 07:48 PM
