how much can a stock T5 take?
Old Oct 27, 2002 | 09:58 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
how much HP have yall been able to get a stock t-5 to hold up to... and what can u do to make it stronger?
Old Oct 27, 2002 | 10:17 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
about 350hp but to make it stronger I do not know
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871057313
Old Oct 27, 2002 | 10:56 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
They are good born warner trannies. I would go for it if you are thinkin about a swap or somethin. If in fact it does blow, you can have it rebuilt, like in that ebay photo above. They are strong durable trannies.
Old Oct 28, 2002 | 12:30 PM
86IROCTHD's Avatar
Car: 88 Trans Am
thanks guys... i think i am buying a 88 iroc for bout 1300 gots a blown motor and i have a bad *** 355 sitting in the garage with aluminum heads and bout 11:1 compression... and i am planing on spraying as well so i want it to hold up better then the automatic i had in the 86.......
Old Oct 28, 2002 | 01:54 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
ummmm, i don't see a stock T-5 lasting longer than 5 minutes behind a stout motor like that. i have a Trick Flow headed 355 w/ 10.2 comp, and the tranny is already on the way out, after just two weeks. i told myself i was gonna be nice to the thing, but it's just a force of habit to rip each gear as hard as i can. these things DONT take abuse very well at all. Slicks are a huge no no, as are hard clutch drops and power shifts. If your extremely nice to it, it'll last for a while, but it's still gonna grenade sooner or later.
Now, there are several people who have had good luck with them, all the way into the low 12's high 11's even, but far more people are dropping them in the mid 14's
Good luck,
Eric
Old Oct 28, 2002 | 04:21 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
If it does grenade, can't you have it rebuilt to last longer for not much money Z28?
Old Oct 29, 2002 | 01:24 PM
knoxbonnie's Avatar
You are looking at about $800 to get one rebuilt if you take it out of the car and drop it off at a shop. Not a lot to do to make it stronger. I rebuilt mine myself for around $500.
Your best bet is to try a T56 or Tremec 3550. The Tremecs are durable, but are a little harder shifting transmission.
Old Oct 30, 2002 | 05:30 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Originally posted by dunerida82
They are good born warner trannies. They are strong durable trannies.
your joking right?
Old Oct 30, 2002 | 08:06 AM
knoxbonnie's Avatar
Yeah, I am pretty vertain that is a joke...
The transmissions are nice and smooth shifting, but the countershafts are too weak to handle any kind of abuse.
Typical problems with these trannies are you will break teeth off the main drive gear on the counter shaft, this cause wear on you input shaft gear and a slight wobble where the input shaft attaches to the output shaft. That wobble then eats up the race on your output shaft and you wind up replacing almost all of the trannie...
Old Oct 30, 2002 | 09:32 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
You might as well ask, which is better the mini or super ram?
Old Oct 30, 2002 | 11:55 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Originally posted by GofasterFirebird
You might as well ask, which is better the mini of super ram?
WELL? ROFL jk
Old Oct 30, 2002 | 07:25 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Originally posted by 1991tealRSt-topGuy
your joking right?
No I wasn't. But looks like I am dead wrong. Someone told me its borg warner. Enlighten me.
Old Oct 31, 2002 | 08:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could the tranny be the vibration i have been getting in my car since a (fairly tame) 350 went in? No vibration untill you go over 3000 rpm in gears 1-3 (not 4, 5 or neutral)..
That just a dead tranny or something else?
Old Nov 1, 2002 | 12:41 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please use the search function. This topic gets asked every week.
Mine lasted for a long time with drag radials and 13.20 timeslips with my current engine. But when I used ET Streets and went 12.80 it broke on the next pass.
Old Nov 1, 2002 | 08:48 AM
BigRuss's Avatar
I have an idea...
Since a lot that I've read states that case flex is the main culprit behind the gears breaking, why not just dip the case in molten steel and let it harden? Sure, it'll add a couple hundred pounds, and probably won't help, but it would sure be *******...
Seriously, someone could probably design a girdle that goes around the tranny and prevents case flex. Shouldn't be hard to install, either. I wonder...
Old Nov 1, 2002 | 11:36 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
flex is only increased with the torque arm
I got an unrebuilt T5 behind my 400 and (for the time being), it has not broke. No factory TA though.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
