Paging Pro Built/transfixleo
Old Oct 28, 2002 | 09:42 AM
Fast3rdGen's Avatar
http://www.tciauto.com/instructions/221100_inst.htm
read through this and tell me if you think step 13 could be my problem(trans locking up when i shift to 2nd gear) i work at a dealer and one of our chevy techs is a th400 guru. he says with just a spring and check ball in there that there could be enough fluid pressure to make that circuit leak causing it to not release 1st gear when it goes into second. he recomended removing that spring and check ball and tapping the hole for a pipe plug. would this cure my problem? reverse, 1st and 3rd gear work flawlessly. only second gear has a problem.
thanks fellas
Old Oct 28, 2002 | 11:50 AM
Fast3rdGen's Avatar
man come on guys!!!!!! every other tranny related post gets umpteen replies and now mine just gets pi$$ed away lmao
Old Oct 28, 2002 | 02:11 PM
Fast3rdGen's Avatar
i'm gunna keep this up top till i get a reply fellas
Old Oct 28, 2002 | 02:41 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Geez man, give it sometime, most people are still at work or in class at this time. I'm having problems with my transmission myself so I can't help you.
Old Oct 28, 2002 | 06:49 PM
kevinc's Avatar
Car: 1982 Z28
Hey dude...you asked for probuilt / transfixleo...I'm not either so I can't help...
Old Oct 28, 2002 | 08:08 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Me neither but my $.02 is if you are waiting for someone to volunteer to help you, you ought to be patient and not EXPECT an answer. Especially immediately. Both those buys have a life to run and are nice enough to chip in because they want to, when they want to. They've both helped me in the past and I'm extremely grateful.
Old Oct 29, 2002 | 04:48 AM
Pro Built Automatics's Avatar
Try Mark at 909-695-0788, he knows TH400 trans brakes very well. This is an Aamco, so ask for him directly (talk to no one else).
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
Dragonsys
Sep 25, 2015 03:51 PM
