tranny keeps going inbetween D & OD while driving.....
Old Oct 28, 2002 | 07:50 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i installed a shift kit a while back and i know it messed up my tranny even more.......(b4 it was starting to slip inbetween gears).......well for a while it worked just find except reverse.......i would have to rev up to 2000-2500rpm's to get it to move......and well one day i was in grass and i tried doing that and it wouldnt really move in reverse so i went foreward instead and ever since when im in OD it keeps going from D to OD simultaneously........is the tranny totally F***ED up or what?
p.s. i plan on getting a different transmission anyway, its just that i still have to drive it occasionally and would like to b able to run 2300rpms in OD rather than 3000 in D.......thanks
Old Oct 29, 2002 | 04:55 AM
Pro Built Automatics's Avatar
Sounds like you have the manual shift linkage out of adjustment. Do not give it gas to get it to move in reverse, you will waste the low/reverse clutches. Solve the linkage problem, and "hope" you did not burn the l/r clutches.
Old Oct 29, 2002 | 10:03 AM
MdFormula350's Avatar
i thought shift kits did not fix slippage in the tranny, i thought you need put a shift kit in only when the tranny is in tip top shape..
Old Oct 29, 2002 | 10:06 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yes i learned that i shouldnt have done it to my tranny cuz it was old
how would i b able to fix that problem?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
