700r4.com?????
Old Nov 8, 2002 | 01:49 PM
mess21's Avatar
700r4.com?????
i need to do somethin to my tranny i wanna keep a 700r4 for the over drive one of the best palces i've found is 700r4.com i'm thinkin bout gettin their stage 3 tranny package anyone have this or rebuilt there stock tranny to these specs any info on the subject would help
thanx
Old Nov 8, 2002 | 02:36 PM
Pro Built Automatics's Avatar
If you want a 700R4 that is done right and with a good warranty, then check me out at www.pro-built.net or give me a call at 800 7763288 M-S 10-6 PST. If I were you I would do some research on what customers say about their transmissions.
Old Nov 10, 2002 | 07:27 AM
mess21's Avatar
anybody else got any input on this???
Old Nov 11, 2002 | 07:51 PM
SuperchargedRS's Avatar
Car: Camaro of course
Ok so there is 700r4.com and bro built.com, and than there is the B&M tranny. Who is the best, and WHY????
Old Nov 11, 2002 | 08:17 PM
4L60bliss's Avatar
I have not heard anything bad about Pro-builts trannies.
I have not had personal experience w/ 700R-4s trannies either.
I did have to go into a crappy TCI tranny, and B&M, need I even say?????
Old Nov 12, 2002 | 11:33 AM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
i have 700r4's parts in my tranny. it held up for two years while i broke in the motor and i think i put about 100 lbs of juice through the motor and like 5-6 thousand miles, drag racing only. and somthing let loose. From what people tell me i may have been the 2-4 band. The car runs somewhere in the low 11.40's or faster.
So needless to say i'm very impressed with how long this lasted. i used all the goodies they offer clutches, pump upgrade, servos, full throttle upgrade and some others.
I had never looked inside a tranny before and rebuilt it myself. It was pretty easy. just had one of the local tranny shops we do business help me stack the clutches other than that i had only minor problems putting it back together. it was messy but fun. :lala:
Old Nov 12, 2002 | 11:59 AM
mess21's Avatar
1989gta ur talkin about 700r4.com's stuff u used???
Old Nov 12, 2002 | 01:27 PM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
i'm sorry my mistake i got my parts from here http://www.transmissioncenter.net/highperf700r4.htm
had to go back to the web site so i would remember
Old Nov 12, 2002 | 03:28 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well, considering how knowledgable Pro Built is, and has been on this board for a while, and all seem to respect him, sounds like a safe bet. I havent checked pricing though.
Old Nov 12, 2002 | 04:41 PM
4L60bliss's Avatar
I've used the "kevlar" band that they sell and was not impressed. The car I installed it in came back 6 months later with a hole punched in the band from the "super servo" they sell. I don't know if it was the servo, the band or both, but neither one I will use again. I now use a non-kevlar, 2-5/8" band, which has been re-inforced in all the right places, including where the hole got punched.
Old Nov 13, 2002 | 08:21 AM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
what did you do about the servo did u put in the corvette servo in rathar than that one?
Old Nov 13, 2002 | 12:07 PM
DO NOT use the "KEVLAR" band it does not hold up or does it have a good shift quality to it. Use the Borg Warner Hi-Energy band. I use this in all my builds (along with the, Corvette servo, large boost valves, accumulator modifications, etc.) and with no failures.
Old Nov 13, 2002 | 12:51 PM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
where did you purchase these parts 700r4.com?
Old Nov 13, 2002 | 03:03 PM
mess21's Avatar
pro built, what are the hp ratings on ur trannys cause the engine i'm finishin up buildin should hopefully be around 500-550 hp and down the line in a yr or so i'm plannin on addin a supercharger
Old Nov 13, 2002 | 03:35 PM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
i have not dynoed the car yet but on the motor it runs 12.0's and with a 150 shot it runs 11.40's somewhere in that range car weights about 3600 give or take 100 lbs. but this is racing cars that run these #'s at the track i have not been to the track for fear of breaking many parts. but i hang with or beat cars that put out these times
Old Nov 13, 2002 | 05:23 PM
4L60bliss's Avatar
Yes, Corvette servo is the only thing I will use now.
Old Nov 13, 2002 | 05:50 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Guys if you want a 700-R4 that will stay with you go with the Pro-Built. I went through a TCI and a B&M 700R4 before I found out about pro-built. I bought one of his tranny's put it in and have no had another single problem. Dana knows his **** about 700-R4's and his customer service can't be beat. He spends alot of time with each customer to make sure you are getting what you want. You can buy an off the shelf tranny from 700R4.com,TCI,or B&M but I assure you if your making any kind of power it want stay there. :hail: :hail: :hail: Pro-Built trannys
Old Nov 13, 2002 | 08:22 PM
mess21 Go to my website www.pro-built.net and you will see what I put in them. The Street/Strip will handle about 550 HP and if you want it to take more HP, then add the HD input drum, this will make it good for about 625-650 HP. After this there is nothing realistically that will hold more HP and still live.
Old Nov 14, 2002 | 08:30 AM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
how long can we expect these to last? Miles, or passes at the track?
Old Nov 14, 2002 | 08:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I've been here since -99 and have read only GOOD things about pro-built! The other companies I've read both good and bad things...Therefor in my eyes the only way to go is pro-built !
Hey Pro-built- have you checked your E-mail?
Old Nov 14, 2002 | 09:51 AM
Benny's Avatar
Pro Built Automatics: Can you ship a 700R4 to Hawaii (Honolulu), if so, how much$$. Thanks.
usertom5057
Mar 23, 2013 05:30 AM
Dmity Kiev
Aug 27, 2009 03:14 PM
18inchboyds
Apr 11, 2006 09:39 PM
Rabbitt
Apr 20, 2005 05:19 PM
formularpm
Sep 15, 2003 04:38 PM
